BigGun
Took forever, but finally finished testing all 24 cells. All tested great with only a 4 AH variance in 24. Resistance is mostly .16 with a few at .17
I'm a carpenter so of coarse my boxes will be wood. These cells don't need compression, but I compress just enough where the cells don't move. The wood strips on one side of the box are removable. I use a thin foam between the cells and the wood. This method worked well on my other builds, so why change now
Triplets
Bus Bars Tomorrow. Lots of holes to drill.
Anticipation Top Balancing First 8
Triplets
