Donald Siegel
- Sep 24, 2019
- 78
I have 8 of the generic used Chinese lifepo4 100-amp cells assembled into a 24v battery with a Daly 40 amp BMS. When charging the battery with my MPP Solar with correct lifepo4 settings I smelled a chemical fume right at the start of the charge, so I quickly switched them off. I checked the bus bars (thick copper bars) and the BMS connections everything was tight and intact. I removed the BMS assuming it was the issue and tried a charge again with the same result, so I disconnected the battery and moved it to a fire safe spot on the cement. I will disassemble it and check each cell to see which one(s) are shorted or damaged. I assume I should just charge each one to 3.4v with a 2-3amp starting current and a 3.6v charge voltage until my amps are zero and see which fully charge to 3.4v and can hold that charge a few days? Is there a better way to find the bad cell(s)?
