Finished my 23 kWh LiFePO4 36v Forklift battery
MilkMan
My forklift's 36v 875Ah FLA battery was barely managing to unload a truck before dying. My new 23 kWh LiFePO4 battery is in and is functioning correctly so far. It should give me about 75% of the capacity that a new FLA would give me. Price wise I'm in it about $5,300 compared to almost $7,000 for a new FLA. I should get $500 for the old Forklift battery too.
Only time will tell with capacity, hot spots, and reliability. I'll need to use it for a few weeks after the holidays and adjust accordingly. I didn't have a good way to capacity test after top balancing. They're out of balance right now, probably from some of my tinkering, so I'm working on that too. I also may have begun stripping a stud that I'm a bit hesitant to unscrew and find out.
For initial acceleration or lifting a heavy load quickly I peak at about 400 amps. Realistically I pull 100 to 300 amps most of the time and only in short spurts. I considered some contactless JBD BMS's but they don't support parallel functions. I should go on a short drive to warm things up and get the BMS fans going. It's cold here right now. During summer when my warehouse is 100 degrees I might appreciate the second BMS more.
Charging
The EG4 charger appears to max out at 25a and not 30a. It'll take around 20 hours to charge from 0 to 100%. My first time using the charger it stopped after 10 hours stating "full charge" but it still needed another 4 hours. Its only setting is to charge to 43.8v or 3.65v/cell. When my BMS turns the charging off, the charger sometimes turns back on 30 seconds later after the cell rests momentarily. With 2 BMS's, one may still be charging while the other turns off, but even with both BMS's disconnected the charger re-engages within a few minutes. Does the Daly BMS have a setting to adjust the voltage for when to enable charging after a high voltage disconnect? I can't find it.
Components
  • 24x Eve 304Ah LiFePO4 cells with laser welded M6 studs (Connected 12S2P) Per the QR codes they were all manufactured in June 2022.
  • 2x 500a Daly Smart BMS /w parallel modules (I don't see the modules in the smart app but I assume they're functioning)
  • Victron 500a BMV-712 Shunt
  • Victron Lynx Power In 1000a bus bar
  • 2x stacked 2mm copper bus bars with nickel plating
  • 2/0 from each 12S to Lynx and 3/0 from Lynx to forklift
  • EG4 Battery Charger 36v 30a
  • 0.25 inch tailgate rubber mat sits between concrete and the cells (The cells aren't compressed but they are tight. They're just loose enough to be removed with some effort.)
  • 1/16th inch neoprene between cells
  • 950 lbs of iron kettlebells
  • 720 lbs of concrete
  • 1 steel enclosure (38" x 17" x 28")
The old battery.
The kettlebells destined to life as a counterweight. Bought for less than $0.50/lb which was the best I could find. I had hoped to find scrap metal but did not find any good fits.
I reused the steel enclosure that held the lead acid cells. There were 3 layers of kettlebells.
The bells are buried. I should have smoothed the concrete. I ended up chipping away rocks to ensure the cells rested at the same height.
Prepping for concrete surrounding the cells.
Concrete enclosure ready. I really wish I would have shortened the height of the steel crossmember. It made wiring the BMS B- and P- a pain. I did chip away concrete that bleed from the sides to the flat area.
This picture gives you a good visual of the rubber/neoprene between cells.
BMS leads all attached and ready for final assembly.
Everything mounted to hardie board and resting on the concrete and steel crossmember. But none of the components are accessible without winching the battery out of the forklift. Total weight is just over 2200 lbs which is what my forklift requires. The BMS B- and P- were barely long enough. I would find a better fit if I did it again. The BMS's are angled for fan exhaust airflow and wire fit.
I'm using the Victron Lynx Power In as a bus bar combiner. Basically wired in reverse of typical use cases but it works great.
EDIT: There are some more updates posted in my reply below.
Nice. I'm preparing to do the same for one of our scissor lifts. One challenge I've not solved yet is there are times when the lifts will be in the weather so keeping the BMS dry is something I need to design for.
My forklift is indoors unless I'm loading/unloading a truck. I could drive in the rain temporarily. The battery slides inside the forklift but there are no sidewalls so some moisture could make its way in. Maybe some type of lid with slanted vents for the BMS's.
Either way, if you get around to it, post some pictures.
My cells were out of balance and my connections weren't perfect. I poured some self leveling concrete to have a perfectly level surface. It worked well.11.jpg
The cells reinstalled and Kapton tape added this time. It's hard to see but I did remove about 1.5" of the steel crossmember so that it would be level with the cells. This greatly helped with wiring the main negatives and positives.
As previously noted I was concerned that I damaged a few studs. Sure enough, 2 of the studs had stripped threads on the upper 1/3rd of the stud. It was the 2 main negatives that the dual BMS B- and P- cables connected to. I was careful on every connection except the main negatives where I was trying to force the lugs down to fit with extra torque. That was dumb.
I purchased a digital torque wrench and the below split die thread chaser with cutting oil. (Boy was the die expensive...) The die did an excellent job of creating a new weak thread that allowed the nuts to pass the damage. Being a split die, I was able to place the die on the undamaged portion of the stud thread and rotate counterclockwise to ensure I didn't cross thread and damage the good threads. As you'll see in a lower picture, I switched to a single 2/0 wire instead of 2 of the DALY 2 awg wires. With only 1 lug I could utilize the undamaged thread to torque to 5 Nm.
I re-did the cement board, shortened excess wire, lengthened the BMS B- and P- wire, and all around cleaned it up a bit.
Lastly, I just wanted to point out I followed Johncfii's method of using Scotch Brite with a dowel to clean the terminals. It worked well. I gave it a solid cleaning with isopropyl alcohol after.
Thats amazing. Great Build! Thanks for posting pictures.
Did you have any problems with the vibrations from movement? any hot terminals?
No issues or hot terminals that I can measure. It's a bit difficult for me to measure each cell terminal temperature with the battery installed and cement board on top. I've been thinking about pulling the battery and checking how the torque measurements have held up. I may also lift a light load up and down with the battery removed and check temperatures that way. The cells are all snug and I run the forklift on flat concrete which should help with excessive vibrations.
MilkMan,
Thanks for posting your build. Thanks to your instructions, I'm getting ready to do the same for my 48V forklift. I wanted to check in to see how your DALY BMS were holding up.
MilkMan,
I've had no issues with the Daly BMS's or really any part of the system. Last week I finally got around to re-checking all the nuts for proper torque specs. I originally tightened the terminals to 5 Nm. Most were now reading between 3 and 4 Nm after 1.5 years of bouncing around. I tightened everything to 6 or 7 Nm this time. I only use the Forklift for an hour per week with the occasional long day unloading a container or truck.
Did you ever start your build and take pictures? If I were to build it again I would likely go with 1 500 amp DALY BMS and wire it 2P12S. I would place the Victron shunt in-between the BMS and the cells or at least test it that way. Since it takes me a month or two to drain the battery, the Victron shunt starts to lose accuracy. I would also use smaller cells since I don't need all the extra capacity.
EDIT: I found the source of my battery drain. It was the Daly BMS's Bluetooth staying away. Once I change the settings to let it time out the inaccuracy was greatly improved.
That's amazing, I want to try build like yours,but How about your charger system,still using the old charger from the factory forklift?
A great post, good work mate & well documented but how did you re mount the battery pack without a forklift ;-)
That's what I did with my Scissor lift. I went from 220 AH to 72AH and have been just fine for the 5 to 60 minutes I use here and there. The entire new battery weighs less then one of the old Trojan T105's! It's still astonishing to me.
Even had enough room to stuff a 1200VA Victron Phoenix inverter in there. Why? Because I could! Lol. Still haven't cleaned up the wiring but some day I will and send pics (nothing is more permanent than temporary...).
BatteryHookup.com still has LFP 74AH LFP batteries I used. ~$23 each, a continuous rating of 180 amps and 600 amps for 10 seconds. Conveniently my lift needs right around 180 amps for both lifting of driving.
I use a 36V EG4 Battery Charger. If my battery were 48V I would have many better options, but this charger can charge from 0% to 100% in 24 hours. Good enough for my use.
The original forklift charger sometimes works. It was meant for lead acid. It has a built-in mechanism that occasionally causes the forklift to give a bad battery error. The original charger allows some voltage adjustments which allows me to set it to the proper charging voltage for LiFePO4.
I have a battery transfer cart that I can roll the battery on to and then very slowly move with my pallet jack. It isn't perfect, but it is good enough. I still use it when I want to check the terminals torque.
Did you add any extra weight to your new battery or around it? I assume your scissor lift also uses the battery as a counterweight like my forklift does? If my battery were 48v I probably would have already added an inverter too. Not that I have ever had the need for it though.
I haven't yet. Been waiting for the universe to deliver me something that was going to get thrown away or scrapped. It rarely gets used and then it's always on level concrete. Unlike your forklift it's not picking anything up and driving around with it, still that's no excuse, I know I'm playing with fire.
I almost left two of the batteries in there before I added the inverter. I'll probably poor an inch or two of concrete in the bottom of the box if it ever leaves my shop.
