You can find an sds on Bromochlorodifluoromethane (Halon 1211) at amerex-fire.com.I have one of those older Halon 1211 extinguishers. It's still showing that it's in good shape. I was not aware of the decomposition.
Personally I love Halon 1211, it works great.
Only use if you need to and only on equipment that is electrical equip, otherwise there are probably better options. Remember they don’t make it anymore and if you do use it it will stay in the atmosphere for thousands of years. It can be recycled but at some point will end up in the atmosphere so best to use if nothing else will do.
btw, weigh it to make sure it matches the weight on the label. The gage is not 100% reliable and halon has a high vapor pressure so the weight will tell you whether it is/has been leaking. The gage will also fluctuate with temp.
