Alanrc
Hello everyone! I've been reading the forums for the past few weeks, digesting information and learning all about off-grid systems. I'll explain my situation then provide info on what I believe to be a good scalable entry point. Hoping to get some feedback on a few elements!
The Property/ Background
The goal of the setup is to have something simple, reliable, cost effective, scalable and relatively easy to troubleshoot. As I mentioned above, relatives will be at the cabin when I am not there so I would need to be able to walk a complete newbie through troubleshooting on the phone.
- Fully off grid summer cabin of appx. 750sq/ft in the Vernon, BC Canada
- South facing roof where we plan to install the panels (appx 30' from the planned electronics shed)
- The west side of the cabin is a very large tree. The roof gets full sun until about noon at which point it begins to shadow from W->E. By about 3:30pm the full roof is shaded by the tree.
- Cabin will be used from mid May through mid September and then winterized
- Our typical daily power usage is around 3.8kWh
- Our fridge, some lighting, and water pumps are all 12V DC
- We may add a 12000btu 120v heat pump in the future
- This is a shared family cabin passed down from my grandfather, and the other co-owners are incredibly price sensitive. I would be willing to pay a larger portion for a more robust and hassle free system (within reason).
- 8 or 9 x 380w Heliene panels in either 3S3P or 4S2P. I was thinking 3S3P to add a panel and the extra string in parallel would help minimize impacts of shading
- EG4 3000 EHV (though this wouldn't work with a 3S3P due to low voltage risk and higher current w/ input rating of just 18A).
- 1 x ecoworthy 48V 100Ah LifePO4 battery (add more as needed if heat pump or other appliances etc installed)
- 48v to 12v converter
- 10AWG wiring from panels to SCC.
- 2AWG wiring from battery to controller
- Am I overthinking 3S3P vs 4S2P? Will it make that much of a difference in the real world?
- EG4 idle consumption is significant, and with it unable to run 3S3P should I be looking at alternatives 2 in 1's or should I consider separating SCC and Inverter?
- Should I go with a 6000w EG4 Inverter w/ split phase for a 240v heat pump, though this would have the same voltage and current issues as above.
- How risky is it having only 1 battery, therefore no redundancy, and of course only 1 day of autonomy (pre heat pump, obviously that would need more batteries)
- Am I missing anything?
