Master Tinkerer
- Jun 8, 2021
- 4
First of all, big shout out to Solar supply house, I ordered the 302Ah CATL Cells Friday night 9 PM, received them today, Tuesday 1 PM. Can’t beat that! (I’m in Los Angeles)
I am using these to replace two 100 amp hour AGMs in an existing system I’ve built. I have a 3000 W inverter running some big loads that are meant to run one at a time, like a 2kw induction cooktop, 2.7kw on-demand water faucet, 700 W microwave, etc. It must be taken into consideration multiple loads will, for sure, be turned on at once creating a peak load over 3kw for a bit until the inverter shuts down.
My understanding is, and please correct me if I’m wrong, you can set a 250 amp BMS to shut down at a preset amperage let’s say 240 A, which will be an extra layer of protection for the inverter.
Question 2
3 kw at 12 V is 250 amps, is this the size BMS I should get?
Question 3
Brand Recommendations?
This is a fairly expensive build, failure/fire is not a good option. Also, this is an Overland/off-road vehicle which does hundreds of miles every year on washboard roads, it is amazing the vibration does not break more stuff then it does, but it does break stuff.
Question 2
Question 3
