Rexracer
This is my truly portable system. I still need to add the Blue Sea Systems 6 port fusebox. I will probably re- mount everything on a slightly bigger piece of 3/4" ply since it's getting a bit crowded. The panels are 160w/18v max (each) and will normaly be run in series. I made (2) Y connectors, 1 for series and 1 for parallel, so I can switch depending on conditions. The panels are under 9 amps max so even in parallel the controller has headroom. I may add another battery down the road if needed. Testing this weekend if the fusebox comes tomorrow. Please let me know if you see any issues! Edit: Just wanted to point out that both the inverter and controller are mounted to 3/4" aluminum square tube, 1/8"+ wall, to allow better cooling. I figured it couldn't hurt.
