Greetings!
From Sacramento CA. Actually live a ways out from Sac and bought 5 acres in the foothills overlooking the valley. Which brings me here.
I wanted to build a shop/garage on the property prior to house. 2150sq ft. 125amp sub panel but no electricity yet. Drywall is up and should start mudding later this week. Have 15 and 20 amp circuits through. Just like a house. There’s a pole on each side but still expect it to cost about 25G to bring in power. If I choose that route when I build house. I have my 34’ rv on property and 3 generators and it’s not bad but want to use solar for shop.
About the only options I’ve decided on is the MPP 5048 split phase. Would like to go with higher voltage panels. Have not decided on batteries.
A couple assumptions.
- I can back feed my sub panel with split inverter so both bars on my panel are hot.
- I’m going to need a lot of panels or also use generator to charge bats.
I think I’ll stop there as not sure if I should be posting all of this here.
Apologies in advance if posting too much or wrong forum.
So hello and look forward to reading learning and watching more of Will on YouTube.
