Been looking around and can't find this answer! I tried interfacing via bluetooth, Sinowealth just sits there "SBS Task Scanning" doesn't move. After about 45 minutes program locks up and locks up the COM port too! I tried it with the USB UART and the same problem... UART is connected to Com 6, select it and it says OK! but the program just can't scan? below you can see what it does. I have tried with just one cell, with 14 cells, I have tried all the different ICs I have tried restarting my computer, disconnecting and reconnecting the BMS, tried it on 4 other BMS's (I have 5 14s battery packs) I have tried using the DalyBMSMonitor (PCMaster) and that just opens the port, never displays a thing... Yes, I am running everything as administrator FYI. I have tried changing the COM port associated with the USB and the bluetooth, no dice.
OH, I have gone through https://diysolarforum.com/resources/daly-sinowealth-software.103/ and the manual with it, nothing in there says what the IC is even for :*(***
Any kinda help would be GREATLY appreciated.
