Rbertalotto
- Nov 26, 2019
- 394
First real test of DIY battery heaters....Last night it got down to 25 degrees. At sunset the temperature was 40 degrees. The batteries in the travel trailer were at 100%. This morning at dawn, the temperature is 28 degrees and batteries are at 93%......the battery box is at 44 degrees. I have the high and low on the temperature controller set at 35/45......could be set lower, but I wasn't sure how reliable or accurate the temperature controller was. I will set it lower. In the Roof Top Tent system, the battery was at 100% at dusk and at dawn it is at 90%. This system high and low is set at 35/40
Both trailer and truck are using the same controller and heating pad.....Trailer has two 100ah Li batteries in an insulated hard case with 420w solar on roof. The truck has single Li battery in a soft side picnic cooler with 200w solar on the roof.
You can read all about the installation and watch videos of the systems here.... www.rvbprecision.com
Hope this might help someone else traveling the same path.
