Hello everyone, I am new here and wanted to start by saying hi and explaining my story (pertinent to why I am going the route I am).
My wife and I moved from the suburbs to the country with 3+acres in northern California, about 1 hour west of lake Tahoe. However 3 days after we moved in our house burnt down in the Caldor wildfire. Good news is our guest house (700 sq ft) and 3 car garage survived. Problem is that was in August 2021 and we have been living here in the guest house ever since with no power because the county will not give us permits for power and water until the state finishes the cleanup process. That is taking forever and I am getting tired of running a generator and hauling water. They will not give us any indication as to when we can get permits or when the work will be done. So my thought is now that I have lots of sun since all the trees are burnt up and being cut down by the state I have the perfect opportunity for Solar. But I am still not going to be able to get permits for quite a while. So I was going to be a rebel and learn how to do my own solar and just install myself without permits. But I run into a few questions. Also out here in the country my neighbors are not gonna give me any problem with having a solar system. Many of them have ground mount system...or did before the fire.
1) I am eventually going to do a large addition on my current house and add another 8-900 sq ft with a contractor. At that time I will need permits and I was not sure how to plan for this in my array and what kind of issues might come up when I go to hook into my solar from the new addition. It will be a master suite and another bath with expansion for the current living room. My plan was to just build my solar system big now (I have insurance money ready to go).
2) Planning for the current setup with future addition, most people recommend looking at your utility bill to figure out KWh usage but, since we were only here 3 days we never had a utility bill. So how do I plan now? Do I just look at all my appliances and figure wattage and guess on hours used? We don't have an A/C don't really need it up here at 4000ft elevation but I figure once I build the addition I will do a mini split. Otherwise most appliances are low draw. my stove is gas, I plan on converting the HW heater to on demand, furnace is gas but fan is electric. My fridge is 450w max but usually draws about 40-110w once its cold. The fridge is the only device I know for certain as I have a bluetti which gives my active readout on watts used and I keep that plugged in to 2 solar panels I have.
3) The system plan I have currently is as follows and it keeps changing as I learn more. I plan on a ground mount system fully off-grid with 20x460W panels. 48V system with 6 EG4 Lifepo4 batteries 100ah each. Then 2 x 5kW Stackable 5000ES (USA Model) 48V 240VAC 100A 450VDC Off-Grid Inverter by Growatt. What if I want to go grid tie down the road? Do I need a different inverter? I haven't figured out how to setup my panels yet (series vs parallel). Of course this doesn't include any of the wires, fuses, and disconnects but that's the basics for now. Also we get up to 3ft of snow at times here so I need to plan for that as well.
4) Finally with gas prices going up and having free electric I was thinking of doing an electric truck. something like the Rivian or Ford Lightning. Is there anything I need to keep in mind when doing this. I can charge the truck during the day off solar rather than batteries as I don't have to commute to work.
Do you see any issues with my plan so far. Living 8 months with no power has me anxious to get this started.
