First Solar Series 6 440w help!
Drakeremoray
So I have a contact that I can pick these up on the cheap but I am having a heck of a time finding a solution for inverter selection that I can drop into my house/shed. I don’t have 3 phase so that’s out. I would like to do a grid tie setup around 15kw. The high voltage and low amperage is the hurdle to jump. Any help would be greatly appreciated!
Specifications:
  • Rated Power: 440W
  • Open circuit voltage (VOC): 220 V
  • Max power voltage (VMP): 184.7 V
  • Short circuit current (ISC): 2.55 A
  • Max power current: 2.38 A
  • Maximum system voltage: DC1500 (IEC/UL)
  • Fuse Rating: 5 A
sunshine_eggo
Happy Breffast!
USA
Many grid tie inverters are 600VDC, so you could go 2S. They tend to also have a 10-20A input current limit, so you could go 3-6S depending on limit.
