I've been reading web sites, watching videos and scouring suppliers' catalogues for a while now, and I feel like I have a handle on the vocabulary and the component parts, but actually deciding on even the basics of a system has me confused.
Here's a system that's settling in my head, but before I start spending actual money I need someone to point out where I'm being stupid...
I'm in the UK so it's going to need to serve 240v AC at 50Hz.
I'll have a constant load (fridge/freezer, network hub, CCTV base unit, security lighting, etc.) amounting to about 400W so ~ 10kWh per day.
I'll have short-term loads (coffee maker, washing machine, tumble dryer, hair dryer, power tools, etc.) amounting to no more than about 3kW at any moment, and in use for short periods (coffee maker takes a couple of minutes (several times every day), washing machine cycle takes 90 minutes, 2 or 3 times per week, etc.) averaging ~ 5kWh per day.
I expect a large inverter to have an 'idle' draw of a couple of Amps, so I'd like to keep it powered down until/unless there's a high load demand. I'll have a small-ish inverter to power the constant loads (maybe this https://www.bimblesolar.com/offgrid...s/1000w-high-freqency-inverter-48v-SHI1000-42), wired to a distribution box and a set of power outlets, which I'll mark "24h". A second, large inverter (maybe this https://www.bimblesolar.com/offgrid...rs/3000w-high-freqency-inverter-48v-SHI3000-4) will be wired to a separate distribution box and a separate set of power outlets, which I'll mark "Not 24h" (or something).
If my battery is 48v the inverters will need to draw 10A and 65A respectively, so to wire the battery to the inverters I'll get away with 14 gauge (1.5mm) for the constant load and 4 gauge (25mm) for the high load.
Drawing 16kWh per day from a 48v battery will take 333AH, so to make up a 3 day 'reserve' I'd need 1000Ah.
To collect solar energy I'll roof mount a P.V. array of 12 x 255W (30.5v, 8.3A) panels (like these https://www.bimblesolar.com/solar/individual/255w-amerisolar-used) (arranged 2S 6P) giving (up to) 61v and 50A (3kW) and feed the result into an MPPT controller (something like this https://www.bimblesolar.com/offgrid/mppt/Tracer6415AN).
My location gets 3.5 sun hours per day (on average), so solar is going to give me 10kWh at most, but wind is plentiful here so I'll supplement it with a wind turbine. Noise may be an issue and VAWT seems the quieter design, but there are way to many warnings about false claims by suppliers on power output so I may need to go with a standard horizontal design, unless someone can recommend a good VAWT supplier.
Power from the wind turbine will go into a 2nd controller, (something like this https://www.bimblesolar.com/offgrid/mppt/midnite-mppt/midnite-classic-150-mppt) with both outputs simply connected in parallel across the battery (I watched Will's video assuring me that they will not fight if I connect them this way).
For a 48v battery I found this... https://www.ruixulithiumbattery.com/12v-2560wh-lifepo4-set-with-200ah-cells-without-bms
labelled 12v, 2560WH, 200Ah (for additional confusion the same thing without a BMS is offered for $120 more)
Stringing 4 in series (for $3750 / £2300) gives me my 48v, but still only 200Ah.
Do I really need 20 of these (4S 5P) to supply my system? Can I start out with 200Ah and see how it goes, and add another 200Ah set later if necessary?
That's the plan so far. If my logic is flawed, please correct me. If I'm being naive or stupid, please point out where I'm wrong. If I've missed anything important, please let me know.
