aonangj
Thank you to those who have helped me via other threads so far to purchase and start to put together my build. I thought it would help to have a singular thread to share the build and ask questions. My many thanks to @Zwy and @OffGridInTheCity (and unknowingly @rodneyhunt) for your contributions already.
Build Details:
7.5kWh Ground Mounted Array
20Kw Split Phase Victron system
Electrical/Panel Tie in
Current Questions:
Build Details:
- 14 Adani Solar 530W Bi-facial panels
- Ground Mount Tilt Array based off of @rodneyhunt's plans on youtube
- Based off of Current Connected 20kVa Kit
- 2x Victron 48V Quattro 10kVA 120V Inverter 140A Charger (UL)
- Victron Lynx Power In - Power Distribution System (M10)
- Victron Lynx Shunt VE.Can - Power Distribution System (M10)
- Victron Lynx Distributor - Power Distribution System (M10)
- Victron Cerbo GX (MK2) Kit; 5" Touch Screen for system control
- 2x Victron MPPT 250V/100A VE.Can SmartSolar Charge Controller
- EG4 LL-S Lithium Batteries Kit | 30.72kWh | 6 Server Rack Batteries With Pre-Assembled Enclosed Rack | With Door & Wheels | Busbar Covers
- TBD - Need to figure this out.
- The Inverter setup is in a shed approx. 150' from my main panel in the house
Current Questions:
- Grounding: I know this is a hot topic. I've reviewed this video and thread but it seems unclear to me. I understand everything needs to be earth grounded, but it doesn't seem clear whether it's better to do a secondary ground rod, or just run it back to the main at the house. Assuming I go with running it back to the house, can I just create a grounding bar in the shed and run all equipment grounds to that AND the PV array to that and then run a bare ground line from there buried with my mobile home feeder back to the main panel?
