Link: Gotion 314Ah 3.2V prismatic
Other links: Blog, Youtube
This is the quote I received:
Gotion 314Ah LiFePO4 cell (32 cells) + DDP = US$2,039
Nothing comes close to giving me 30kwh at that price. I’m wanting to put them together into a 16S2P configuration, 48V in my RV for full-time boondocking. Potentially expand to 16S3P in the future if needed. Axle weight is more of a limiter at that point haha. I will be installing two JK-PB2A16S15P (150/300A), one for each 16S. Sized to allow each S-string to fully supply the 5kw inverter in-case one BMS goes down. Inverter limited to 4kw on BMS (existing RV wiring limits).
I've been lurking in the forums, I know Docan can be hit-or-miss. This is my first foray into DIY solar, and my first large purchase. I’ve been doing my own research for weeks, but I’m at the point of information overload from watching long Youtube reviews (that I'm so grateful for).
Questions:
- What should I realistically expect from these "A-minus cells" performance-wise. I'm not looking for capacity perfection, but also don't want bloated/damaged cells.
- Should I order extra cells, or an enclosure (planning on simple fabric-tape compression), or a proper battery charger for initial top balancing?
- It comes with busbars, is there a minimum thickness I should request?
- What should I ask for re the cells/shipping? The quote does not include any test reports.
Holistically:
It’s my first time, I don’t need perfection. I’m going to have fun putting these together and learning more about DIY batteries. I want to learn how to test cells and monitor their performance over time. But I mainly want to hook up into my RV, and hit the road, and don’t want to spend 3 extra months arguing with a seller.
Thanks for any advice!
Questions:
Holistically:
