Butcher72
Thanks for the member approval.
This is my first post here. First, I do have some experience with solar at an off grid cabin that I build. But... this will be a first for me to set up in a small class B RV, that has it's own electrical already, just no solar.
My plan, and acquired items. (12V system)
Two Allpowers 200W flexible panels mounted to the roof VIA internabond tape
An entry gland (has 10F of 10awg cable and MC4 connections and 50A BUSSMAN breaker)
Renogy 50A DC-DC MPPT controller with vehicle alternator option, 4AWG cable from alternator - controller with 80A BUSSMAN breaker
Chins 300AH 12V battery
Renogy 3000W pure sine inverter with built in transfer switch, 4/0 battery cables for battery to inverter (1 foot in length with 400A ANL fuse)
400A distribution block / buss bar
10AWG ground cable to ground everything VIA the chassis.
Contemplating between a Powermax Li Converter to replace the old converter not capable of proper Li charging, either the PM3 or PM4? (your thoughts)
Where my lack of knowledge lies?
The Renogy inverter has a built in Transfer switch and "shore power" input, my thought would be, I wire my shore power plug into it (SKU number is anyone is interested in checking it out RIV1230PU-126-CA)
But what happens with the electrical from my onboard 2800 onan genny? Do I keep it wired to the present transfer switch, and from there in conjunction with the shore power?
Should I wire the 12V side of RV panel directly to my battery with a fuse / shut off in between? Or will it do its "own thing" when I hard wire the panel into the Rengoy Inverter?
looks like I got room for this equipment to fit under the driver side storage area under the "eating area" seat, but will open up two sides with a 4" hole saw, and put screen for ventilation.
This is a pic of my camper van, any info would be greatly appreciated.
My wife and I, did a Ontario to Alberta trip in it last year, and a few weekend trips around Ontario and Quebec. This year we took just over a month off of work, and are going to British Columbia for the month of September, and there will be quite a few weeknd trips during the summer. We prefer to be "off grid / boondocking" and not camped at RV parks. Hence the solar set up, I'd rather not listen to a genny running.
Thanks
Thanks
