First timer solar issue
chariotman
I have a lifepower 4 24v 200ah battery. It's working fine, but it has the alarm and run lights flashing in a ratio of 2:1. As far as I can tell the manual says that means in charging state with a warning. I can't figure out from the manual what that means. I haven't had it connected to power in a few days and the soc has only one light on. Please help. This is the item if you can understand the manual more than me. https://signaturesolar.com/eg4-lifepower4-lithium-battery-24v-200ah/
Low voltage cutoff.
Charge the battery.
That's what I was thinking. I'm surprised that it got that low though since I wasn't using it. Thank you though. I thought that might be the case, I just wanted to ask in case it was something far worse.
