Which remote control do you have? You can access the various temperature readings of the unit and see if any of your thermistors are bad.
Or, if your unit has wifi(and not the stupid Alexa dongle) you can download the midea Smart home app and it will tell you the various temperature readings so you can see if one is off.
I had units that somehow were a lb low so I vacuumed out and weighed refrigerant back in.
Or, you can just add a . 25lb at a time until it starts working correctly.
page 6 service inquiry codes.
you'll want to find out the cods for 0-5
1. Simultaneously press ON/OFF and FAN SPEED for 8 seconds.
a. The remote is now in the INQUIRY mode.
b. The remote control remains in the INQUIRY mode for 1
minute if no other button is pressed.
c. While in the INQUIRY Mode, the remote display cancels all
icons except AUTO, COOL, DRY, HEAT and Battery
Strength.
d. The remote control digital display defaults to 0 upon entering
the INQUIRY mode.
e. In the INQUIRY mode, each digital code (from 0 to 30) is
accessed by pressing the UP or DOWN arrows .
f. The INQUIRY information appears on the high wall indoor
unit display in approximately 1 second after accessing the
digital code. Press OK to send as well.
g. In the INQUIRY mode, all other buttons and operations are
invalid except for UP, DOWN and OK or the operation to exit
the INQUIRY mode.
Remote Controller Service Mode Functions
Note: While in the INQUIRY mode, refer to the following
instructions to enter SERVICE mode for the applicable codes.
Below is a list of INQUIRY modes and serviceable functions.
a. Before using the remote’s service functions, turn OFF the
indoor unit with the remote.
b. Turn OFF the power to the outdoor unit for 2 minutes. Turn
the power back ON.
c. Remove the batteries from the remote and wait for the remote
screen to clear. Within 30 seconds of replacing the batteries, use
UP or DOWN to scroll through the INQUIRY modes.
d. To enter the SERVICE mode for an applicable INQUIRY
mode, press ON/OFF for 2 seconds.
e. After SERVICE adjustments have been made, press ON/OFF
for 2 seconds to exit the SERVICE mode and return to the
INQUIRY mode.
f. Once operations in the INQUIRY mode are complete, press
ON/OFF and FAN SPEED for 2 seconds to exit. All buttons
on the remote controller are disabled for 60 seconds
g. To ensure changes are locked, power down the outdoor unit for
three (3) minutes after all the service mode changes are made.
