This is also a good reason to not mount the BMS balancing ring terminals below the serrated nut.If you don't like scratches then don't use a flange nut with a serrated surface. The flat washer will allow the flange nut to turn. A flange nut against a bus bar is far less likely to turn because the bus bar doesn't move.
I believe you are referring to my system busbars.It scratched through the coating on mine. I seem to remember you having some nicer busbars. That is why I mentioned it.
I would say you un-muddied the water.I'm going to muddy the water.
I was planning to use grub screws and with 1oz busbars to connect my 280ah cells.
for the busbar connects from the bottom up would be...
terminal1oz busbar(ring terminal) for the balance/sense pointsflat washerlock washer6mm boltFor the most positive and most negative
terminalmechanical lugring terminalflange nut
I used a flat washer and flange nuts, probably not ideal if the nut is going to work loose, however I believe ths won't happen on the battery. The use of studs over bolts is the only way to go if you won't to stop the chance of stripping out a thread in battery terminal. I also used a hi tensile grub screw instead of stainless steelI will need to use grub screws with my big blue prismatic cells.
I plan to use flange nuts with the grub screws.
I understand the flange nut will make a lock washer unnecessary but do I need a flat washer?
Prior to ordering parts I’ll forum-search and read opinions. This makes sense to me and ArthurEld‘s comment about serrated scratching drove home the point. ...ordered smooth ss A2 flange nuts. Thank you...I've disassembled many hybrid vehicle packs. None use washers or serrated flange nuts, and they pass 100-150A of current and absurd amounts of POWA! Stack: Terminal face, bus bar, smooth flange nut. For the connection that has sense leads: terminal face, bus bar, sense ring terminal, flange nut.
Properly torqued nuts will not come loose, washer or not.
Personally, I prefer smooth flange nuts for more accurate torque values.
