So #2 is still alive?
Yes, checking phasing with the outputs disconnected is what is implied in the instructions when they said to have the output line breakers to the units turned off. The inverters would have done that check and showed an error if there was a problem. It would not have blown if those breakers were there and open. BUT they do not show the mentioned isolation breakers in the wiring diagram so how are you supposed to do it correctly the first time? From what I could tell in the manual there are no breakers in the inverters for that purpose. True? Then I would complain that the instructions (wiring diagram) were wrong, leading to this disaster. The one being out of warranty is irrelevant. It failed by random chance. Would they have covered it it the 2nd one was the one to pop instead?
