Howdy folks,
First solar setup. Everything from the panels, mounts, j-boxes, disconnect switches, wallmount batteries, etc worked exactly as planned with exception of the GridBoss/FlexBoss combo. I've had my gridboss / flexboss system in production for a week, trying to fine tune my system so I don't need to touch it again for a decade or so. I have encountered a few features that do not work per spec, or in the way advertised, or are just missing completely. Signature Solar has guided me through a number of undocumented workarounds to some of the issues, what I lovingly call "hacks" that can resolve some of them.
Here is my list. Let me know if these are resolved. Please link to other issues so future buyers are aware of the current status of these issues. I'll try to stay on top of the thread and will update this post as needed. I want these products to succeed and be relevant for many years.
Sincerely,
Your humble unpaid beta tester.
Software Config / Performance –
- FlexBoss21 Manual vs. Software settings vs. Signature Solar settings. Many of the settings in the software do not do what you would expect. In order to keep my battery throughout the night I have to Activate A/C charge, then give a time period, then trickle charge the battery for the time period. Seriously? What is the point of having a manual if none of the settings in the software work the way they should. Every modification to settings practically requires a call to Signature Solar because the settings do not do what you think they should do. I can only guess that someone thought it better to staff with lots of technical support techs instead of writing an accurate manual and quality software. The problem is when I need to make a change on a weekend or if EG4 goes bankrupt, or I no longer have the latest and greatest inverter and no one is familiar with it. PLEASE UPDATE YOUR SOFTWARE AND MANUALS SO A SKILLED HUMAN WITH ELECTRICAL KNOWLEDGE CAN OPERATE IT WITH CONFIDENCE!
- FlexBoss21 Optimal string voltage is claimed to be 120V-440, but does not appear to work even when string voltage is higher than 140V. This is costing me production I was planning on. https://diysolarforum.com/threads/flexboss21-error.98378/
GridBoss may not be able to handle high pass through current from the Grid. Awaiting resolution. Resolved in beta firmware provided to SlowRoller 2/2/2025. https://diysolarforum.com/threads/gridboss-with-flexboss-not-handling-21kw-pass-through.97560/
Pressing RSD button on FlexBoss21 shuts down GridBoss backup load even though the grid connection remains active. Not user configurable. 2/5/25 EG4 Tech confirmed this is intended. There is no mention in the manual of main grid shutdown during RSD.
GridBoss Smart Ports - Signature Solar Tech warned me the Smart Ports may not work in a grid down scenario when I was asking how to set it up with my EV charger. I asked three times to confirm. They said they double checked with level 2 tech. This may be a training issue with that poor tech, but I'm putting it here until proven otherwise. Ports verified to work 1/31/25 with Grid down. See this thread. https://diysolarforum.com/threads/gridboss-smart-loads.98598/
- Time of Use settings described on page 45 of the FlexBoss21 settings do not exist in the inverter settings. Requires workarounds to enact and the techs were unable to create enough workarounds to meet my 3 pricing periods. Also unable to handle weekend pricing. https://diysolarforum.com/threads/flexboss-21-time-of-use-settings.98597/
Cosmetic – simple workmanship issues that make me not want to show normal people my system:
- Web monitor does not provide picture of Flexboss21 when linked to Gridboss – its just a nebulous square. Upload a nice selfie please!
- Indoor Wallmount conduit box top cutouts do not line up with GridBoss punchouts.
- Copper only - this was well documented but nobody uses copper at 200A!
@EG4TechSolutionsTeam
