I have 2- 6500ex48 inverters, one has the ground neutral bond screw removed. The other provides the single neut/grn bond location for the system.
I have a 4 pole transfer switch , when using generator power ( 4 wire 240/120vac) , the generator neutral is floating. It's a honda eu6500is inverter model.
Can I just bond the generator neutral and ground conductors at the main panel neutral bar?
Will this damage the generator?
