Hi. I have a large lead acid battery bank (12 tubular deep cycle flooded lead acid 12v batteries connected as 48v system). They are fairly new (probably 75 cycles max). Then I decided to switch to lithium iron phosphate with which I'm very happy. However I don't want to get rid of my lead acid batteries. I want to keep them to supplement my lithium iron phosphate batteries when demand is high or for those cloudy days when there isn't enough sun to recharge the lithium batteries. I have tried this and found that on many days the lead acid batteries are not used at all (stay at 100% soc) and on some days they get used down to 95 or 90 % soc. Rarely, they get used a bit more heavily and go down to 80% soc. So the lead acid batteries are either not used at all or very lightly cycled. Whenever used they get recharged back to 100% soc within 12 hours max. My question is: with the way I'm using my lead acid batteries, will they last for a VERY long time since they are being cycled so lightly (a long time in calendar days/years)? Or is such light use detrimental to the batteries in some way? I mean if I calculate their cycle life with these shallow and infrequent cycles then theoretically they should last for many years (as long if not longer than the lithium iron phosphate batteries which are doing most of the work on a daily basis).. right? Or am I missing something? Do lead acid batteries degrade with time whether used or not (calendar degradation)? If so, then cycling the lead acid batteries so lightly is actually wasting these batteries which I could be working harder and preserving my lithium iron phosphate batteries by cycling them less. Any info on this topic would be appreciated. Thank you.
