ConradPoohs
- Apr 22, 2022
- 3
Hi,
I would appreciate your help confirming that everything is OK with my charging system please.
I have just replaced some old flooded batteries with a LiFePo4 320Ah pack. All balanced, connected and set as recommended on this forum (an YT). The Daly BMS 100 settings are below (14.40/12.00 V cut off). I have customized the Morningstar MPPT45 controller as recommended with max absorption 14.40V (no temperature compensation and equalization). Once the battery is back to 100% SOC the DALY BMS cuts off charging, the bluetooth BMS Smart app shows nicely 0 Ah and solid 13.8V (going down quickly from max 14.4V).
However, the solar controller MSView software shows fluctuating voltage (up to 21V) but no current. I can see similar fluctuations 10 meters from the charging system/battery at my 12V sockets...
1. Is it safe for my batteries and equipment to ignore it or should install some kind of additional regulator (shunt 14.4V) as a barrier for these voltage
I can physically switch off the connection panels/controller and obviously it stops that issue but it can't be monitored all the time.
2. Another question - the Battle Born Batteries in setting up the MPPT controller at:
changed the Absorption voltage to 14.40V but left the absorption time as 2.5h. Is it correct?
Please let me know what could be done about it.
All the best,
Conrad
All the best,
Conrad
