Thanks for responding about the panel angle. Not having to worry about the angle for season changes AND having significantly more panels to provide some good, usable power even on completely cloudy days is spectacular!
Personally I would not call it spectacular, but the next phase of evolution.
The whole setup is spectacular
High quality components and good Installation skills!!
Your car probably CAN drive 200km/h, but you probably never are going to use that potential power.
Driving uphill is easy.
Km/h isn't the correct information, better use torque and horsepower, you understand the similarlities.
Having offset angle means less fluctuating power production.
Yes, you miss out on the peak.
In more ideal situation you don't want to need the peak, but the overall productivity.
My peak is 14.3kwh, overall (about 9-10kw.
And that's double / triple to our daily usage.
Living off grid is also no* alternative power.
With current price of solar panels
Under $0.26 per watt (mono crystalline), it's no longer "needed" (affordable) to grasp that peak.
With a price under $75,- per LiFePO4 Kilowatt storage, that is also really affordable.
Just 2 years ago it was double....
* We do have some wind turbines and for emergency, 6.5 KW generator (gasoline/LPG)
