for sale: 200Ah 12V LifePO4 Rechargeable Battery
all1
Up for sale is a 12V 200Ah Lithium Deep Cycle LiFePO4 Rechargeable Battery in excellent condition. It comes with a built-in BMS board sealed inside ABS case, Powerful & Reliable Starting Power. Supreme Performance & Reliability.
More about the 12V 200Ah LifePO4 Rechargeable Battery Specifications:
Nominal voltage-capacity 12.8V 200Ah
Single cell voltage: 3.2V
Cell type: LiFePO4
Box material: ABS security case
Discharge cut-off voltage: <10.5V
Max charge voltage: 14.6V
Max continuous charge current: 50A
Max continuous discharge current: 200A
Instantaneous current: 250
Promised Life Span:2500 cycles (-40C to 50C under normal temperature)
Weight: 60 lbs
Amp Hours:200 Ah
Size (LxWxH): 20.5x9.4x8.6in (523x238x218mm)
Nominal Energy: 2560W.
This is a High Quality Deep Cycle Batteries With High Efficiency & Long Life. Suitable for EV, Bus and Power Tools.
Asking price:USD$1250
If you are interested kindly send me a message,
allsales at protonmail dot com
Thanks for looking...!!!
