These were 2Kw ( 35Ah cells )do you have the spec for these?
I'm currently looking at buying some of these batteries from BHU and was just wondering why you sold yours. Was it the high voltage?James007ht >> these are the specs.. only difference is that my batteries have the balance cables.. these don't..
https://batteryhookup.com/products/bmw-oem-16s-57-6v-35ah-2kwh-module-1
gpower07 >> The packs are about 30 pounds i think..
more info..
16s 57.6v 35ah 2kWh
I have 1 of these also I would like to sale if you are interestedI'm currently looking at buying some of these batteries from BHU and was just wondering why you sold yours. Was it the high voltage?
Just one? How much? Any why are you selling it? I'm wondering if its a bad idea to try and use 16s lithium-ion pack because the voltage is so high. BHU suggest cutting it down to 14s, but I'm not sure how to make that work (and they couldn't tell me) and by doing that I'm losing capacity. Having a hard time with this decision.I have 1 of these also I would like to sale if you are interested
Yes I only have the 1, I would let it go for 200.00 plus the shipping. Have you purchased your inverter/charger yet I'm pretty sure there are several inverter/chargers that will work well with these batteries, my 12kw Growatt does not have the range to work well with these batteries, And I am already using Prismatic cells in a 16s configuration.Just one? How much? Any why are you selling it? I'm wondering if its a bad idea to try and use 16s lithium-ion pack because the voltage is so high. BHU suggest cutting it down to 14s, but I'm not sure how to make that work (and they couldn't tell me) and by doing that I'm losing capacity. Having a hard time with this decision.
Where do I find the manufacture date on the battery and I purchased mine a little over a year agoWhen did you buy yours? What is the manufacture date? I want to see if it’s from the same batch I’m getting from BHU.
I sold them because i couldn't use them for 48v setup.. Voltage was too high for my use.. I think i let them go too cheap.. I used the money to buy other batteries.. I did good as those 16s were free.I'm currently looking at buying some of these batteries from BHU and was just wondering why you sold yours. Was it the high voltage?
The manufacture date on my battery is 12/05/2015There should be a day code stamped on the side of the case like below. But I've decided not to use Lithium-Ion and instead use LifePo4.
