FOR SALE: OutBack Hybrid Energy System
era1
OutBack Power SBX5048-120/240 SkyBox Hybrid Inverter 5kW 48VDC 120/240VAC
The inverter runs perfectly
SBX5048-120/240
Grid Support Utility-Interactive
Non-Isolated Inverter/Charger
INVERTER DUTPUT
Maximum Continuous Output: 5000VA @ 45°C
Maximum Ambient Temperature Rating: 60°C
Derated Continuous Output @60°C: See manual
Nominal Output Voltage: 120/240VAC
Maximum Continuous Output Current: 24AAC
Output Power Factor Rating: -1 to 1
Nominal Frequency: 60Hz
GRID AND GENERATOR INPUT
Operating Voltage: 120/240VAC
Input Operating Voltage Range-
Grid: 211.2 to 264VAC • Generator: 170 to 285VAC
Grid Maximum Input Current: 48AAC
Generator Maximum Input Current: 48AAC
Max Output Fault Current: 227ARMS / 511Apeak for 198s
BATTERY
Nominal Output Voltage: 48VDC
Input Voltage Range: 42 to 60VDC
Temperature Compensation-
Default: 5mV/°C • Range: 2 to 6mV/°C
Maximum Input Current: 140ADC
Charger Derated Continuous Output @60°C: 3000W
Charging Output Voltage Range: 42 to 60VDC
External Overcurrent Protection Device Rating: 175ADC 10kAIC
Maximum Output Fault Current: 798ADC 188us
PV ARRAY
Maximum PV Source Voltage: 600VDC
Operating PV Source Voltage Range: 200 to 600VDC
PV Maximum Input Current: 20ADC
Maximum PV Source Short-Circuit Current: 32ADC
Maximum Utility Backfeed Current: 420A for 7.45ms
COMPLIANLE
• Conforms to STD UL 1741 SA
• Conforms to STD CSA C22.2 No. 107.1
• Enclosure Type 3R
• RoHS
Asking: $2,650
Hit me up with a PM if you're interested. Thanks.
Please put your location in your ad title!!!!!!!!!!!!!!!!!! At least the state, some of us prefer not to ship items that heavy.
