LibertyPro
The converter in my RV, which was supposed to have been Lithium compatible, turned out not to be. So while I charged my 2 new 12v 100Ah LiFePo batteries individually up to "full" through this converter - the max voltage the converter was sending to the batteries was 13.6v.
I have procured a new, lithium specific, converter and have confirmed that it can supply the full 14.6v to the batteries. I can set it to either just run at 14.6v all the time, or to a 3 stage where 14.6v is for the bulk charge only.
Anyway, since these are new batteries I'm wondering if I should/need to let them charge at 14.6v for a while to get the cells to properly balance still? And if so, I have a couple questions:
1) Do I need to discharge them first before charging them back up at 14.6v, or can I just charge them at 14.6v at whatever current state of charge they're at now?
2) How long should I let them charge at a constant 14.6v before switching the converter back to the 3 stage mode in order to ensure the cells are all properly balanced?
(fyi - these are WattCycle batteries and when I balance the cells in them, I'll be doing so individually whereas for normal use, they'll be connected in parallel.)
Thanks for the info!
