justinm001
- Dec 18, 2022
- 2,031
Idk about all that. My daily average of my 19cuft fridge is .35kwh. Idk how efficient it is but I can't find any heat source with a flir.pretty simple math.
My 10 cubic 120V fridge at home needs about 1.5 kWh electric / day, Most fridges have about a COP of 2-3. So those are then 3-4.5kWh of heat generated.
Those are 3 kWh of heat you need to move through the A/C requiring you another 1-2kWh to get rid of it.
Sure if your main scenario is - heating - then a interior vented fridge is awesome - it's additional "free" heat. But if you are mostly cooling - it's terrible.
The 12V RV fridges - for example Dometic are designed as drop in replacement for Absoprtion and are venting to the back into the old cavity - so "external"
I also don't think it works like that as any cold air that escapes from the fridge goes into the rv offsetting the temp.
I'd think Absorption fridges introduce much more heat than electric into the rv because insulation only helps so much and it literally uses heat to suck cold air out
