JG51Ogg
- May 15, 2021
- 14
Hopefully someone can make sense of what I'm about to say.
Property 5 miles from civilization and running power to it would cost in the range of $35,000 to $50,000 depending on permit costs (this is just the power companies estimated cost of running the lines and poles).
For 2 sheds, 3-30 foot travel trailers and a hand drilled shallow well with electric well pump.
Started with a 4000w Generac gasoline generator. Plenty of power but hell on gasoline usage (two trailers, and a well pump). about $50.00 for a weekend
Built 12x16 shed to house a 12Kw home built diesel generator. Generator runs on a 25% diesel 75% waste oil mixture. Cost $8.00 for a weekend
Added from the shed to the trailer area power disconnect that can handle 12Kw of power (State building code) going to an Outdoor Service panel that breaks power to each trailer.
Original intentions were to build a Cabin capable of sleeping 15-20 people at the same time in the cabin plus room for visitors in trailers. Cabin has since been set aside.
Added third trailer and another 12x16 shed for toys so we don't have to transport them when we go there. Added in power drops for those in the outdoor panel.
And now
Wanting to eliminate the noise of the generator at night.
Built in a 12x88Ah 12v battery bank and a 2000W modified sine wave invertor to be used for night time power of well pump and necessary electrical use at night. Worked like a charm. During the day the 12Kw Generator would run and supply power to the charging system of the batteries. But now, as with all lead acid batteries, they are beginning to die over night and we are looking at new alternatives that do not require any use of fossil fuels.....Did I mention the Diesel Engine self destructs about every three years. Tired of rebuilding the engine.
We have come to the conclusion through trial and error (mainly buying different generators) that we really only need 2000W @110V to make it through the day running the 3 trailers and 2 out buildings (3000 if we run the A/C in the trailers) with a surge start of 1500 additional from the well starting.
SO now come the questions about our future system.
We have made a modest start with acquiring 2-250W panels.
During the summer we will build a rack system and clear the land around it to hold the panels on a variable vertical mount. We will be tying them into a controller and into the battery bank. We plan on also over the summer building 4-310Ah 12V LiFePO4 (16cell total) batteries to replace the old batteries with. Along with this we have also acquired a 3000W Pure Sine invertor with 85% efficiency and 4A no use draw. Since this system will only be used for two or three days at a time with a couple of weeks of charging by the 500w of solar panels the question then becomes how many more panels would be needed to keep the batteries charged if it were to be used in a continuous situation for, let's say, 2 weeks.
Now understand also this is near Lake Superior and when the sun goes down the temperature drops 20 degrees as soon as the sun hits the trees. So the only thing being used at night even in the summer is a couple of LED TVs, a DVD player, and a Satellite receiver, with an intermittent hit from the well, and a high efficient refrigerator.
Is there a formula that can be plugged in that tells me Watts of solar needed to produce 12V power to run 85% efficient invertor to run 3000 max watts daily?
I may have missed seeing it but I just found the YouTube channel and never thought about building my own batteries before but now that I know it can be done I think we'll give it a run.
Thanks for any advice.
And now
