lmwilco1
I have a Chargery BMS8T for sale. Included are all of the parts and cables except for the shunt. I was using the shunt for my BMV712 so I tossed the original shunt. You can order a shut from Victron or other suppliers. Included are the relay delay board, a small relay board that drives the main contactors, and two Tyco 500A contactors with the energy saver circuit. I also have the inverted precharge resister and relay and two toggle switches to manually turn of the charge and discharge contactors. I used the Chargery for a few months and found that I can run everything I need on 100A so I switched to another BMS.
$75.00 for all. Flat rate shipping is $13.50 or local pickup in Tempe AZ.
Louis
Louis
