I am assembling a Solar system for My 2014 Montana 5th wheel. I have 4 x 200 watt Grape solar panels (and room for 4 more later). 2 Renogy 40 amp mppt Charge controllers, 1 Renogy 3000 watt inverter/charger, and 4 x 100ah Renogy Smart Lithium Iron Phosphate batteries. Batteries in Parallel. I believe I need a 315 amp mega or Anl fuse on the Inverter Positive and a 400 amp class T fuse on my positive Battery post after the shunt ? 4/0 welding wire for all battery and inverter connections. the panels will be two sets of two in series, with each feeding a 40 amp controller. Main connection point will be a Victron Lynx Distributor. what did I miss? Thanks in advance Jim Oh and thanks for a great book Will !
