I have a small solar set- up with a Growatt controller for my well. Not long ago I changed to two LifePro 24 volt batteries. I just watched Will Prowse's video, about new cheaper LifePo batteries.
In it he states that despite assumptions to the contrary it's important and preferred to regularly fully discharge and fully charge these batteries regularly.
Because the rainy season is in full swing here my panels are not charging anyway so I thought this would be the time they'd likely discharge fully. However now I get no load to the pump for my water needs. It seems I would need to charge the batteries up to run the pump.
I'm not sure if I can get full discharge without running the pump, but my cut-off level seems to have been reached at 24.0 and no load is possible even with a reset.
