SomebodyInGNV
- Jun 3, 2020
- 182
Hello. I'm connecting 4 Newpowa 180W panels(1) in a 2S2P array to an EPEver Triron 4210N MPPT solar charge controller(2). The panels will be mounted flat on an RV roof and frequently shaded by trees. Initially, I will not have an inverter and my battery bank will be the pair of 215A 6V GC2 Duracells I already own. They're in good shape. I'll upgrade to LiFePO4 later and add an inverter at that time.
I want a switch between the PVPs and the SCC. Should I use a breaker? I'll have a total of 720W which may result in occasional clipping but won't exceed the max PV power, so a breaker doesn't seem necessary, correct? If a breaker is advisable, can I use an auto-reset breaker so it resets itself when the current drops? I'd use a separate switch as well, in that case.
I also want a switch between the SCC and the battery. Is there any reason for that to be a breaker or fuse? I already have a Blue Sea Systems switch which I can repurpose.
If relevant, the converter charger is the OEM WFCO 8955.
1. Voc 19.84V, Isc 11.75A
2. Max Voc 100V, rated PV current 40A, rated PV input power 520W/12V, max PV input power 1560W/12V
