rillweed
Let's assume I have 1 panel (200W, 20V, 10A) connected to an MPPT with a disconnect switch. This setup has no need for a breaker since the panel is a limited power source but what happens if the MPPT malfunctions and causes a short and backfeeds from the battery? Is a fuse needed for that scenario to protect the solar wire? I have read quite a few threads on not needing a breaker for small systems in series but I haven't seen anyone mention this
I am using a victron mppt and I know they have some internal fuses but I don't know that they will prevent this. The victron install manual for the 100/30 actually recommends using a fuse between the mppt and the panels. Is it in case of malfunction or are they generalizing?
