mitchk1303
- Feb 3, 2020
- 52
Hello all. I am trying to wrap my head around the reasoning for using different fuse types. I understand the interrupting amperage rating. I guess my question is about the necessity of T-series fuses.
I will start with my potential setup:
2x 206Ah lithium batteries with high current protection
1x 100A 12v fuse block
1 x 3kw victron inverter/charger
I am planning on using 2 225A T-series (or maybe MRBF?) fuses on each battery with 2/0 cable to the bus bar.
I think I will use one 4/0 cable and 400A fuse from the bus bar to the inverter.
My question is why is T-series fuses recommended for the bus bar to the inverter? Isn't the system already protected by both the battery short circuit protection as well as the fuses in between the battery and bus bar? It seems like the T-series fuse would be redundant. I get having a fuse to protect the cable but it seems as though it wouldn't have to have a super high AIC rating? Any thoughts would be appreciated!
