poorman137
- Sep 22, 2021
- 3
make sure you use a circuit breaker -2 pole- on the output of the PV controller. One pole for solar panel disconnect & one pole for output disconnect. This way if the controller output goes over current & trips, the breaker, it shuts off the solar panels. The way everybody is telling you to fuse the output is wrong. Their way ,If the controller output fuse blows then the panels will burn out the controller.
