WorldwideDave
Solar Wizard
I have 4 batteries. 2 are new store-bought, 2 are DIY. All are 12V lifepo4. All have 100A BMS or greater. All cells are 1C rated (I think - know for sure 2 of the packs are).
Going to connect these all in parallel, but cannot put a MRBF on the positive terminal of the DIY batteries. So i was going to run conductors from all 4 batteries to a 6 post bus bar. on the bus bar I was going to have 6 MRBF holders - 1 for A/C to D/C charger, 1 for the solar charge controller, and the remaining 4 for the 4 batteries in parallel.
Originally I was going to run all 4 batteries, each with t-class fuse, to the bus bar. But it seems that might be overkill for 100Ah 12V batteries.
I was going to consider running 4 batteries to their MRBF hanging on a 6 post bus bar, then run a t-class fuse between that bus bar and another bus bar #2, and on bus bar #2 I would then hang 2 other MRBF for the SCC and AC to DC charger.
Thoughts?
Thoughts?
