Hi people, newbie here. Im going to add a 500W / 24V wind turbine, on the 1000W PV off grid system, so batteries can get some extra juice during the night.
I know that hots should be fused between rectifier(or)/controller and the battery system, and between the battery system and inverter.On the internet, I've seen people adding 3 fuses between the wind turbine and the rectifier/controller. So my question is: What is the point of fusing on that spot. Is it necessary and why? What happens if one fuse accidentally goes off? Will the turbine run freely and get damaged?
I did a quick drawing to help you understand.Thanks for your time.
