Got pics of what you did? Likely I will do the same on the next 3...I completely unsoldered the original BMS and put the new BMS in it's place. Just needed some wire to go from the battery to the new BMS. The red and black wiring on the original BMS I reused on the new BMS to go from the input/output and also hacked the ribbon cable from the original BMS so I can get the display to turn on and show the voltage.
