Maast
Compulsive Tinkerer
Probably not of much interest to anybody, but I was poking around their online store looking to pick up another couple of contactors because I was reading the specs on the ones I have and their max coil voltage was 54V. Doh! There goes another couple hundred bucks.
At any rate it turns out the GV series are dual coil units that turn off one coil after activation bring their hold wattage to 2 watts, which is nothing and impressed the heck out of me, I think thats less than a SSR usage. Also the GV series coil voltages go up to 64V. And they were cheaper than my originals. Picked up a 200A GV221FAX for $85 and a 400A GV241FAX for $95, no sales tax and no shipping charges.
The reason the coil voltage is important is because the Chargery passes along the battery pack voltage as the coil control voltage if its running off the pack for power.
Thought I'd pass it along.
Edit, for those that arent aware, Gigavac relays/contactors are absolute top quality relays made in the USA and will outlast your grandchildren. Their online store filters are easy to use and you can find a high power relay in any configuration you could ever imagine. Their ratings are for true continuous duty.
Product selector: https://www.gigavac.com/catalog/power-products
Online store: www.gigavac.com/shop
