I am new to solar, but I am extremely proficient in hooking up 110V generators (I take it that your 1000 watt generator does not provide any 220 service) to the home, including how to crank the generator automatically (if it is cranking battery equipped) when it needs to turn on (and off) and to safely integrate it into the home and still be UL 1008 complaint.
To do this safely you'll need a transfer switch. There are numerous manual ones but only one automatic one I know of for 110 volt generators. It comes in a 10 circuit
https://www.apc.com/shop/us/en/products/APC-Universal-Transfer-Switch-10-Circuit-120-240V/P-UTS10BI and 6 circuit variety
https://www.apc.com/shop/us/en/products/APC-Universal-Transfer-Switch-6-Circuit-120V/P-UTS6 .
I seem to recall at one point that Honda was bundling this automatic transfer switch under the own label, addition to APC selling to other dealers. Honda may still do so.
If you want the generator to start (or stop) automatically I recommend either of these: the more to do one:
http://atkinsonelectronics.com/gscm-generator-start-control-module-rev-c-5-13/ or
http://atkinsonelectronics.com/gscm-mini-60hz-usa-canada/.
It's pretty straightforward to start and stop a generator based on the presence or absence of either AC or DC current, the latter can also be set to a voltage threshold.
I've done what you wish to do it sounds like. If I can be of help please post back. Of course I am a hobbyist seeking to help for only good karma.
