Most fire rings have long been removed from our local beaches. No more BBQ on the beach.Or to use your bbq.
Common enough that they have a web site for rolling blackout schedules.Rolling blackouts in CA are not exactly a common issue.
Power Outage Awareness Map
Find the latest information on an electric outage in your area.www.sce.com
generator fires,
6 people sent to the ER with CO poisoning
one elderly lady died.
That is a blackout for safety.... not a rolling blackout for lack of generating capacity.Yep. I know of a small community that Edison cut power to due to the power lines blowing into trees in high winds and starting fires. When they first started doing that 2 years ago, everyone dragged out their old generators and fired them up. 2 houses burned to the ground due to generator fires, several other fires damaging parts of homes, at least 6 people sent to the ER with CO poisoning and one elderly lady died.
The power goes out until the wind dies down. I have seen it out for just over 2 weeks.
If the main is open why is it illegal? Or deadly? Who are you yelling at?me backfeeding the panel with the main open is deadly, illegal, and starts an internet war
Yes CA actually has a plan and it has happened a couple times. Not to be confused with TX where there was no plan causing extended blackouts, people died of exposure, no water due to the municipal pumps shut down, hospitals evacuating. In CA they have a plan to prioritize hospitals, police, fire and municipal services for public safety. Still rather uncommon to go dark due to lack or generating capacity.Common enough that they have a web site for rolling blackout schedules.
Actually they are quite common these days. It's called a PSPS and it is happening more frequently.Rolling blackouts in CA are not exactly a common issue.
Some small engine power equipment uses propane. That should handle the applications where battery powered isn't sufficient.
Actually, it's because Texas decided to be on their own and then decided it wasn't worth the money to design the power plants and wind farms to work in sub zero weather. They have windmills all over the world where it gets colder than Texas got. Texas just has a mis managed power system.Ok, I actually live in TX. There was no plan for the fluke weather event we had, because it was just that - a fluke. No "reasonable" plan would have prevented it. Many of the issues were due to the "go green" people who forced some of this stuff on us. So the solar farms became covered with snow and frozen ice, the windmills becoming frozen, and a few other unfortunate coincidences happened (NG plants down for maintenance because we don"t normally have severe weather at that time of year). Sure there were a few deaths, just like there are every year in northern states in the winter. The event lasted a whole 3 days and then we were back in the 70s. The media exaggerated a lot of what happened.
I was without power for 3 days and got by with one 2kw inverter generator and a couple of indoor propane heaters. The genny was just to keep the fridge running, but I could have just as easily put that stuff outside. Sure, I learned a few lessons too, because all of my planning was for outage issues when it is 115 outside, not a fluke winter weather event.
I'll also state that all the new equipment have cats, a good chunk of them are fuel injected, they all have charcoal canisters to trap evaporative emissions, and the fuel cans as we all know suck. So where is all the pollution coming from?
Only a fifth of Texas's power comes from wind and solar. There natural gas power plants are basically what failed. They failed because they couldn't work in the cold weather because ERCOT didn't want them to have to meet the standards that the other 49 states have to live to.Texas' grid is mostly closed off from the rest of the country by choice in order to be exempt from a lot of federal regulation, FYI. I wouldn't say it's grid is mismanaged in general. In this case it was more that they are overly dependent on solar and wind and got caught without out sufficient base load generation capacity when they most needed it due to a confluence of events that combined about zero renewable generation with a gas shortage plus some ill-timed plant maintenance, plus high demand caused plants to automatically go offline after sustained low frequencies (< 59.4hz) over a period of time to prevent damage.
Holy run-on sentences, Batman!
