Dakota Rose
- May 8, 2022
- 4
I purchased 7 used Chilicon cp720 inverters on Ebay. Got a fantastic price (less than $40 each). I then purchased a new cp100 gateway.
I've slowly built a solar rack with 12 310W panels, two feeding each of 6 inverters. One of the inverters is discovered as a "repeater". I can't find any documentation on how to reset it. My gateway is also showing I have a 5KW array, which is not true so I assume was programmed previously.
Secondly, every day at around 10 am I lose communication with the inverters and gateway. PLC survery shows no ping return from the inverters. They're still producing power, but have no communication with gateway.
I set up several arrays with cheap plug in grid tie inverters; just to see if solar was worth it. This is the first array I"ve set up with micro inverters like this.
Any help would be greatly appreciated.
