Stephen Kelsey
Texas Bluebonnets
After having an electrician install my Generac manual transfer switch for my Generac gasoline generator which works fine with the generator, I plugged in a Pecron 3600 single phase only, which is all I need. No 240 loads on the transfer switch. Just wanted to have something to offset the gasoline use .
Find out the rocker switch from utility to generator only works with 240-volt generator. I can take the cover off an use the little metal bar to throw the switch but was wondering if anyone else had this issue and found a work around the switch.
Appreciate your time
