Hoping I can post as this not a DIY question, but I’m looking to understand some things a bit better as I look into solar, specifically about battery backup options to go along with a solar system.
I was mostly focused on kWH of capacity and how long it could last (answer: not very long for whole house), but one guy I spoke to today emphasized another factor which is max current. Regardless of how much capacity the battery has, it can only output at a certain rate.
He was offering a Panasonic Evervolt which has a max current output listed of 31.7A. So even though I think it’s have enough kWh juice to run my AC for a bit in the evening, my old inefficient AC is on a 40A breaker for the compressor and a 20A breaker for the air handler. So it seems like that even 2 such batteries couldn’t actually run my AC at least not with the fridge etc ?? Is that correct?
The other offer I have for a decent amount of battery juice uses the Tesla Powerwall 3s. So I went to check their specs, but I’m not sure how to read them. There’s an initial brief start capacity of 185W, but that’s not continuous.
There IS a “maximum continuous current” but the spec sheet lists it in 4 columns ranging from 24A to 48A so I’m not sure how to interpret that. The 24 would be less than the Evervokt, but the 48x2 batteries if 96 seems like it WOULD be enough current to power my AC, at least for as long as the kWh last?
Am I understanding this right in general? And could the PowerWalls handle it?
