I'm looking at the Growatt 24v SPF 3000TL LVM. I like it bc it has MPPT, has parrellel already included, has generator backup auto start, 24v for modern car battery conversions like bigbattery, 140v and 2000w input seems good enough, and stacked will give me 6kw when I really need it.Growatt disclaimer, " The generator is a different beast to the solar charging. It does not use bulk or float charging" You set parameters 12 and 13 for the generator to turn on and off. Then set parameters 11 to charge amperage - too much will stall the Genny or cause it to go out of phase. So how high can it charge?
I was looking at Will's website and that sent me to another website with the all-in-one inverter/controllers and I saw MPP and Growatt. I noticed that grow watt had a disclaimer in their description. Under the utility power input it had 60a which sounds great, but I'm a bit confused though.
Do the Growatt and MPP trickle charge the batteries? If not how high have you set it?
The main scenario I foresee is that we run the batteries down over 3 cloudy days then the generator will automatically turn on. Then I assume our 3500 watt generator by going through the grid input will output the max 60 amps and runs stuff as well as charges the batteries with what's not being immediately used. I could swap with my dad's 7000watt generator to charge faster.
So the big question, does it charge the batteries at a trickle like 5amps or something and will take all day running to fill up? Are we going to get up to the max amperage from our genny charging the batteries, minus anything used immediately? Maybe a hard start capacitor would help at Genny start up?
If it is a trickle charge - long shot - Next comes to mind is use the generators front AC plug to add to the Growatt slow charging by essentially having the AC plug on the front of the generator go to a 20a plus charger that charges the batteries. Maybe a 24v boat charger.
Their warning has me worried the system would suck in the scenario above and I would have to run the generator until the sun came back out and the solar array then charged the batteries back up again. We would have two controller running a 15kwh battery bank (3 of the bigbattery .com banks on Will's site). Do I need two generators? One for each controller?
In worry bc many RV chargers have a slow float charge that sucks and I have experienced having to run the generator all day to charge up the RVs' 2 small batteries. So many people tear out the old charger and add their own 40 amp chargers.
