hi ,
can someone help with this problem/idea iv got.
i would like to connect a generator up to a grid tie inverter, to work with the grid mains income.
dont want it to work as a back up so happy for it to turn off when no grid power.
dont want solar panels connected to it.
just a generator connected to a grid tie inverter to supplement my house electrical supply.
is there an inverter out there for this ?
i have a 5kv diesel generator.
was looking at a string inverter with pv input up to 500vdc
then using a bridge rectifier to change ac from generator to 330vdc and feed it in through the pv connection.
would the 330vdc from generator need to be a smooth dc.
or could it just be a full wave rectified input. not sure if this would make the inverter turn on and off as voltage would drop to zero in between each wave.
thanks
for any input.
thanks
for any input.
