Greetings generator gods.
a new generator purchase is on the books. I’m partial (but open to anything) to Honda simply for the fact our current genny (2000eu) has served us well for 15 years, running daily 7 days a week during cabin season , 3 hrs in the summer, and up to 7 hours late fall.
I’m entertaining a predator, but I live in Canada, so it’s a minimum 4 hour round trip for warranty, etc.
the current use of the generator is for our off grid cabin. I’m talking actual off grid. There is no grid, no plumbing. We’re talking 2 hours out of the city, off the highway, up a road, and onto a boat.
genny is mainly at night for lights, Tv , cell booster, and soon to be starlink. We also charge a smaller battery pack to power my c pap, and 12v shower. It’s actually quite wasteful.
for now the goal is to build a “solar generator” consisting of a trophy 48v, 100A battery, Morningstar inverter, and the new chargeverter from eq4. It has the ability to dial in the amperage, so I can match it properly to the generator.
the idea is instead of running the genny each and every night, we start off with a full battery. Then every 3-7 days charge it back up. Eventually I’ll add a charge controller. But,for now no array.
trophy recommends charging “up to” 50A. Less is better.
as I said I like Honda. Not sure if I should stick in the 2200 range, or bump up to the 3000, or 3200. I looked at the 7000i. Seems like a bit overkill for my needs. It has 240, but I’m not sure if it’s an advantage for my needs or not.
I’m a bit confused with Hondas 3000 range. They offer 3 models. Very similar, but the new 3200 has a lower running wattage than the older 3000.
so, gods of generation what say you?
honda? Yes? No? how big? 240?
noise isn’t a deal breaker but as a courtesy to neighbors I’d like quiet (although they won’t have to put up with nightly generator usage).
I know there’s not so apparent differences with the Hondas, I.e some are carb’d, some have a fuel pump. Not sure if any have EFI. The new 3200 manual talks,about timing belts. Yikes. Our old 2000 has had oil changes, spark plug changes, and I think a couple pull strings. That’s it.
in a nutshell I need up to 50A of charging. I want reliable, somewhat quiet, and something that makes sense in Terms of peak efficiency, fuel economy, etc.
looking for that “sweet spot”. As for money, I’ll gladly spend what I need to, but dont Like spending more than I have to.
